LIGHTWEIGHT BODY MANAGEMENT - NX7.5
Please, download the attached file.
I need to create a parameterized part, using whatever this file contains.
I got this file importing (Import/Part) a “DirectModel Document (.jt)“ file.
Never worked with this kind of file (DirectModel Document (.jt)), I can’t select anything.
Do you have any solution for this task?
MZ7DYJ
RE: LIGHTWEIGHT BODY MANAGEMENT - NX7.5
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
This is FACETED data and there are multiple approach you can take.
In my case i have used Four point surface to fit surfaces and then trim them off (but in NX8.5 i would recommend creating some points first and then group and finally use FIT PLANE....).For sheet metal parts this makes more sense.Else you can create a suitable plane and take section and then proceed with those curves.
I am attaching a parasolid file (i have NX8.5 with me so no idea if NX8.5 file will do for you).
Please note that i have not created cutouts and pockets and since i am travelling so might need to check the accuracy of my rapid creation...
Best Regards
Kapil Sharma
MZ7DYJ
My company has NZ7.5 only! I can't use later version!
MZ7DYJ
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
www.nxjournaling.com
MZ7DYJ
I just need to learn how to create math data using LIGHTWEIGHT body........
MZ7DYJ
