what do you add before lift pour?
When you have tight column formworks set up and ready for pour. Do you really have to pour a liter of water to wet the old column surface at bottom of column or pour a liter of grout before main pour? What is the purpose of such? What do you usually do?
RE: what do you add before lift pour?
If the bottom is sealed airtight, the liter of water would remain, so no problem with it mixing with the pour and affecting the cement water ratio at the bottom most section?
