Trace Error / Calibration Failure Amada FO-3015 NT
What could cause a sudden trace failure with no change to the cut conditions and an HS calibration failure, as well? I've removed the ECO head, checked the Z-sensor wire, cleaned the head and cone and I'm completely stumped. Any help will be greatly appreciated and thanks in advance.
And no, the "trace off" option has not been used.
RE: Trace Error / Calibration Failure Amada FO-3015 NT
Do you have another cone (most people call this the head) that you can try?
