Temparature measurement
I am designing a temperature measurement circuit for measuring temperature of a oven. Temperature of the oven is around 650 K. I heard that thermistors and RTDs can be used for temperature measurements. But I couldn't figure out which is better. Can somebody give some suggestions ?
RE: Temparature measurement
There are also thermocouples.
Why are you designing this, as opposed to buying one? Is this for production, or one-off installation?
As for which is better, VE1BLL's thermocouple suggestion or an RTD: You need to consider the desired accuracy, cost, package, range, and other things.
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
www.engineeringcalc.com
