Cantilever beam modeling
Hi, this might be a very basic question but I can't solve it.
I'm having problems in getting the same results with different models, first I modeled a cantilever beam using a 3D deformable wire model, it is attached on one end with a step force on the other, the result I get is as expected, the tip displaces and at some point bounces back a little.
Now I need to attach a PZT on top of the beam so first I tried modeling only the beam using a 3D deformable solid with the exact same material, loads and BC's but the displacement I am getting now is only continuous, it does not return at any point.
Does anyone know why is that? since I need to attach the pzt to the beam, I need to make the 3D solid behave like the wire one.
the beam is a small steel part 300x15x1mm,
I appreciate any help or tip you can give me.
Daniel.
Daniel.
RE: Cantilever beam modeling
