Setting Viewer Background Color results in error
Hi Guys,
I have the following code:
CODE
Dim objViewer3D As Viewer3D
Dim objCamera3D As Camera3D
Set MainDocument = CATIA.ActiveDocument
Set objCamera3D = MainDocument.Cameras.Item(1)
objViewer3D.Viewpoint3D = objCamera3D.Viewpoint3D
Dim DBLBackArray(2)
objViewer3D.GetBackgroundColor DBLBackArray
Dim dblWhiteArray(2)
dblWhiteArray(0) = 1
dblWhiteArray(1) = 1
dblWhiteArray(2) = 1
objViewer3D.PutBackgroundColor dblWhiteArray
Comes up with error: "Compile Error: Function or interface marked as restricted, or the function uses an Automation type not supported in Visual Basic" on the "GetBackgroundColor" and "PutBackgroundColor" code.
I'm not doing this via catscript, but the normal Visual Basic window.
Anyone got any ideas or another solution?
Version V5R18.
Cheers!
RE: Setting Viewer Background Color results in error
Hi
I suppose you are trying to get a screenshot....should work...
CODE --> vba
Dim MyViewer As Viewer
Set MyViewer = CATIA.ActiveWindow.ActiveViewer
'-----get Active Background
Dim color(2)
Dim MyViewer2
Set MyViewer2 = MyViewer
MyViewer2.GetBackgroundColor color
'-----set white background
MyViewer2.PutBackgroundColor Array(1, 1, 1)
'code to capture screen in what image format you want and path
'-----back to original backgroung
MyViewer2.PutBackgroundColor (color)
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
Thks Fernando, I looked at it a while ago and could make it work... How many times do we have to trick CATIA to make it work??
For those who did not notice:
CODE --> vba
Dim color(2)
Dim MyViewer2
thumbsup2 star for you
Nice
Eric N.
HI
I tried ferdo's code but still my background colour stays in white. Doesnt get back to old color after putbackground colour statement. Am i missing something
Any suggestions
Barath
