Surface Modelling in Solidworks
Hi, I'm a bit stuck on trying to cap the edge of my design.
My design is a organic shaped handle and I 'am trying to model the the edge part which is a dome , but so far I 'am struggling to achieve this. trying to get the same style of end piece as the picture i have been using. I have acheieved the design so far by drawing different planes along the to scale picture and then surface lofting between the planes which have the different radi's on .
The idea after is to make the end part and then thicken the part to create and solid handle.
If any one nows or has an idea of how i could achieve this any help would be great.
cheers,
cheers,
RE: Surface Modelling in Solidworks
I would do the end(s) first as that would give you more control over the tangencies rather than lofting to a sketch profile.
https://www.dropbox.com/s/9c6j0nj355aeqf0/handle%2...
Dan
www.eltronresearch.com
Dan's Blog
