Journal cycle problem. CAM operation transform
Journal creates cam operation mirror through a plane. It works when executed on operation, but when item is a group object I'm getting en error (see attached file).Please help me to get this journal working.
CODE
Option Strict Off
Imports System
Imports System.IO
Imports System.Windows.Forms
Imports NXOpen
Imports NXOpen.CAM
Imports NXOpen.UF
Imports NXOpen.Utilities
Module MirrorCAMops
Dim theSession As Session
Dim theUfSession As UFSession
Sub Main()
theSession = Session.GetSession()
theUfSession = UFSession.GetUFSession()
Dim WorkPart As Part = theSession.Parts.Work
Dim setupTag As Tag
Dim selectedTags() As NXOpen.Tag
Dim selectedCount As Integer
' If there is a work part only then we can go further
If WorkPart IsNot Nothing Then
theUfSession.Cam.InitSession()
theUfSession.Setup.AskSetup(setupTag)
' If there is a setup only then we go further
If setupTag <> 0 Then
' Get the selected nodes from the Operation Navigator
theUfSession.UiOnt.AskSelectedNodes(selectedCount, selectedTags)
If selectedCount = 0 Then
MsgBox("No operations selected.", MsgBoxStyle.Exclamation)
Exit Sub
End If
Dim ptr As IntPtr = New System.IntPtr
Dim cycle_cb_fn As UFNcgroup.CycleCbFT = New UFNcgroup.CycleCbFT(AddressOf cycle_cb)
Dim datum As NXOpen.Tag
Dim datumPlane1 = select_a_datum_plane(datum) = Selection.Response.Ok
Dim i As Integer
'Loop over the selected nodes to take action
For i = 0 To selectedCount - 1
' The selected item needs to be checked to take action
action(selectedTags(i))
' Now if the selected item is a Group object then we need to cycle objects inside it
theUfSession.Ncgroup.CycleMembers(selectedTags(i), cycle_cb_fn, ptr)
Next i
End If
End If
End Sub
Function cycle_cb(ByVal camObjectTag As Tag, ByVal ptr As IntPtr) As Boolean
Dim answer As Boolean
' Every item needs to be checked to take action
answer = action(camObjectTag)
Return answer
End Function
Function action(ByVal camObjectTag As Tag) As Boolean
Dim camObject As NXObject = NXObjectManager.Get(camObjectTag)
'Check if the object is a Operation
If TypeOf camObject Is CAM.Operation Then
Dim objectsToTransform(0) As CAM.CAMObject
Dim operationTransformBuilder1 As CAM.OperationTransformBuilder
Dim origin1 As Point3d = New Point3d(0.0, 0.0, 0.0)
Dim normal1 As Vector3d = New Vector3d(0.0, 0.0, 1.0)
Dim plane1 As Plane
objectsToTransform(0) = camObject
operationTransformBuilder1 = WorkPart.CAMSetup.CreateOperationTransformBuilder(objectsToTransform)
plane1 = WorkPart.Planes.CreatePlane(origin1, normal1, SmartObject.UpdateOption.WithinModeling)
operationTransformBuilder1.Plane = plane1
operationTransformBuilder1.TransformType = CAM.OperationTransformBuilder.Transform.MirrorThroughAPlane
operationTransformBuilder1.MoveCopyInstance = CAM.OperationTransformBuilder.Result.Copy
Dim nXObject1 As NXObject
nXObject1 = operationTransformBuilder1.Commit()
Dim objects1() As NXObject
objects1 = operationTransformBuilder1.GetCommittedObjects()
operationTransformBuilder1.Destroy()
End If
Return True
End Function
Function select_a_datum_plane(ByRef datum As NXOpen.Tag) As Selection.Response
Dim message As String = "Datum Plane:"
Dim title As String = "Select a Datum Plane"
Dim scope As Integer = UFConstants.UF_UI_SEL_SCOPE_ANY_IN_ASSEMBLY
Dim response As Integer
Dim view As NXOpen.Tag
Dim cursor(2) As Double
Dim sel_mask As UFUi.SelInitFnT
theUfSession.Ui.LockUgAccess(UFConstants.UF_UI_FROM_CUSTOM)
Try
theUfSession.Ui.SelectWithSingleDialog(message, title, scope, sel_mask, _
Nothing, response, datum, cursor, view)
Finally
theUfSession.Ui.UnlockUgAccess(UFConstants.UF_UI_FROM_CUSTOM)
End Try
If response <> UFConstants.UF_UI_OBJECT_SELECTED And _
response <> UFConstants.UF_UI_OBJECT_SELECTED_BY_NAME Then
Return Selection.Response.Cancel
Else
theUfSession.Disp.SetHighlight(datum, 0)
Return Selection.Response.Ok
End If
End Function
End Module
RE: Journal cycle problem. CAM operation transform
You need to cycle through the group just collecting the operations in an array then once done cycling through the group run through the array mirroring the operations.
