High strength steel replacement for A105 and A516 Gr 70
Looking for a recommendation to replace A105 and A516 Gr 70 carbon steels with much higher strength ones, with good machinability, equivalent corrosion resistance and nickel plating suitability, for use in high pressure fluids for which A105 and 516 are typically used.
Steven Keays
www.naiad.ca
RE: High strength steel replacement for A105 and A516 Gr 70
Do not treat them as you would SA-516 regarding welding. I've recently seen a number of heavy wall vessels require extensive repairs of cracks when treated like SA-516.
