model series of check dams with hydrocad
[URL=http://imageshack.us/photo/my-images/507/checkdams...][/URL]
Uploaded with [URL=http://imageshack.us]ImageShack.us[/URL]
model a series of check dams as ponds
is it ok to just connect each pond together (see hydrocad model below)? my question is the tc I am using comes from the north west corner and down to the dam when the pond flows through the swale. DO i need to separate these somehow?
[/URL]]
RE: model series of check dams with hydrocad
my question is should the tc be modeled like this? even tho it doesn;t show most hydrologically distand point I feel likt it is modeling the flow throught the swale? now sure. thanks
[/URL]]
just note my first picture is also 3 subcatchments i just forgot to outline them with red like I did in the third pic
The Tc should be calculated just to the next node. The pond routing is already causing a a time delay due to routing effects. Including the pond in the Tc calculation will double-count that portion of the flow path and should be avoided.
If the distance between the check dams is significant (1000+ feet) you might use an intervening reach to simulate the travel time.
For details see www.hydrocad.net/tc.htm and www.hydrocad.net/checkdams.htm
Peter Smart
HydroCAD Software
www.hydrocad.net
after doing some reading i think my first approach may be the right one? no need to add another tc for flow from one pond to the next? hydrocad calcs the time to fill up each pond in the routung calcs? no sure. thanks
thanks psmart, so my first 2 drawings ( i know they are crude ) look like a good aproach to you?
Yes, the first sketch shows the approach I recommend. Each Tc flow path should end at the next pond.
Peter Smart
HydroCAD Software
www.hydrocad.net
thanks
