Welder Qualification
If a welder is qualified to weld on CS, can he weld SS materials? Please guide where can i find the answer to this?
MNT
MNT
RE: Welder Qualification
Thanks...
The short answer is that per ASME Section IX (the code, as well as me, lol) a welder qualified on 'carbon steel' (P1) is also qualified for P-No. 1 through P-No. 15F,P-No. 34, and P-No. 41 through P-No. 49 (stainless steels include P8).
Having said this:
The welder is restricted by QW 451.1 as well as other process limitations, as stanweld has indicated.
There are a few if's and wherefores that have to be checked first. Remember what the letters in ASME stand for: Always, Sometimes, Maybe, or Except.
Best regards - Al
Gerald Austin
Iuka, Mississippi
http://www.weldingdata.com
Welder Qualified Details
1. Material - Its known P1
2. Welding Consumable Used
3. Process
4. Thickness
5. position
Then
For SS welding , whcih you wanted to use the welder
1. Process
2. Consumable
3. Thickness
4. position
Aakash Jha
