Weld length question - Using NX7.5.
Hello
Does anyone know if it is possible for NX to generate a 'total length of weld' (i.e. for all welds on a big assembly) and output that figure to an attribute?
Thank you for any suggestions.
P.S. If you use the auto weld symbol in conjunction with the weld command then you get a value output in the weld symbol for the individual weld length... I tried to use this as a start but don't know how to get a summing up of the lengths...
Solid Edge; I-Deas 7 to 12; NX4, NX5 & currently NX6.
