foundation fieldbus confusion
from what I read foundation fieldbus is digital, but I often see people representing the signals as AI (FF) and AO (FF), is this correct? (A=Analogue)
Are the following statements correct?
FF devices have analogue input and analogue output function blocks only inside the device (for example a pressure transmitter).
When a signal is transmitted from a FF device to DCS, the signal will be converted to digital before transmitting.
Finally, On the I/O list I have a level transmitter transmitting signal to DCS, so the I/O signal type should be AI (FF) or just FF or DI (FF)?
RE: foundation fieldbus confusion
does this mean Foundation Fieldbus can transmit 4-20mA signal if analog blocks are used?
i thought FF replaced 4-20mA?
