Constraints with limits
Hi!
I'm here with another question, and I would be very glad if someone has helped. Is there a way, how to define constraint with limits? For example, I'd like to define that this node can move only by 2 millimeters, no more.
Thanks for any reply.
RE: Constraints with limits
re-reading your question, do you want to ...
1) stop the structure deflecting after 2mm (as though the structure has contacted the ground) and then react load ? or
2) make the structure stiff enough so the point only deflects 2mm ?
1) is contact, 2) is much harder (it's a structural optimisation problem, changing the stiffness of the structure to limit displacements).
Quando Omni Flunkus Moritati
You have two options:
• CBUSH element allows to define in the PBUSH property where you can enter a curve of load vs. deflection and run a nonlinear analysis SOL106.
• CGAP elements, where you can define a GAP distance (the two mmm) and the compression stiffness when the GAP is closed. You can run linear SOL101 analysis or nonlinear SOL106 analysis.
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48011 BILBAO (SPAIN)
WEB: http://www.iberisa.com
Blog de FEMAP & NX Nastran: http://iberisa.wordpress.com/
