How to stop automatic alignment of annotations created using NXOpen in NX 7.5?
Hello Everyone ,
I am encountering this weird issue in drafting in NX 7.5.
I am creating some annotations in my NX drawing using NXOpen Code and staggering them at some location (not in the center of the dimension line), but when i hit the view update button , the positioning is all lost and everything is aligning to center of the dimension line in case of linear dimension.
I wish to know if there is any setting that helps me retain my dimension value position inside the dimension line without letting it change on hitting the view update button.
Please help as this is causing me a lot of trouble.
Thanks and Regards,
Amitabh
Thanks and Regards,
Amitabh
