pipe insulation cost
hoe to calculate/estimate the cost of insulation when
Volume: pi(d) x Length x thickness
V : m3 (meter cubed)
given: price/meter (USD/m)
so, the total price will be? volume (m3) x price/m ?
RE: pipe insulation cost
You may also like to take into account:-
Material
Cleading
Degree of difficulty in applying
Valve boxes or not
Environment
Vapour barrier
“The beautiful thing about learning is that no one can take it away from you.”
---B.B. King
http://waterhammer.hopout.com.au/
If you are given a price in $/m, the only other item you'd need would be the length of piping you need insulated.
Ask your question to two or three insulation contractors. So many valid things are mentioned already, but equally haven't and can only be answered on the job. Scaffolding I could add for one.
Johan Sentjens
www.linkedin.com/in/johansentjens
