a/s iso9001 bearing assembly clean room
Hello Everyone just inquiring some information i grind bearings for a company that is a/s and iso9001. I also assemble these bearings, without a contamination/clean room. Please tell me there are standards for this room and where to get it. My boss wants to put it next to the sandblasting room and open grinding machines(i.e. centerless, O.D. grinder)
Trying to avoid failure I'm taking it upon myself to make sure this is done right. Thank you for all your time in this matter
RE: a/s iso9001 bearing assembly clean room
Like maybe your bearings must apply to some ASTM standard and that implies that miniature and instrument precision bearings for example require cleanrooms per ISO 14644-1 and -2,etc..
Then those standards will specific the micron filtration/laminar flow,etc.. for the standard required specific cleanroom classification. Class 10,000,etc...
http://en.wikipedia.org/wiki/Cleanroom
