Plate top vonmises stress
Abstract:
I have problem with analize with beam elements and plate elements model.
I have used model with spring dof element and rigid element.
I have used nonlinear static analize.
Problem:
i can't find Plate top vonmises stress in "post procesing data"
wojtekmath
Abstract:
Problem:
wojtekmath
RE: Plate top vonmises stress
Are you sure that you checked the Stress Results in Outputs ?
Best regards
Everything is checked. Still nothing. I don't know what is wrong.
Quando Omni Flunkus Moritati
Plate x membbrane force
Plate y membbrane force
Plate xy membbrane force
plate x bending moment
plate y bending moment
plate xy bending moment
plate X TransShear Force
plate Y TransShear Force
beside it i have:
- total, T1, T2, T3 Translation
- total, T1, T2, T3 Rotation
- total, T1, T2, T3 Constraint Force
- total, T1, T2, T3 Constraint Moment
- beam: force, moment, strain, stress
- spring axial force
- gap force
then 9 times click "next"
window: "nastran output request"
section: "elemental" checked:
+force 0. .Full model
+stress 0. .Full model
+strain 0. .Full model
i have big bath, inside is fluid. This bath is supported by steel construction. Between bath and construction i have springs. And in some place springs was fully crushed.
Results is that in this places bath have plastic deformation.
sorry for my english :)
I can't check plate stress, because femap don't give me it back in results.
tick "corner stress results" (under "customisation")
maybe also change output option to "print and postprocess" so you can see the raw nastran results, the f06 file.
i have had "postprocess" clicked but not "print and postprocess"
huge thanks
but if it works, it works ...
