MDF laser cutting
MDF laser cutting
I am looking to cut MDF on a 2.2kw bysprint. I am looking for some advice regarding doing this such as parameters etc. Also, if its 6mm MDF, would you sent the material thickness to 6mm, and turn of height sensing..? Im fairly new to this and not sure if when the head comes down will it detect when it is just above the mdf?
Thank you for all advice given.
Simon.
Simon.
RE: MDF laser cutting
-HR
