Bridge Curves Jumping on Helix Curve NX7.5
I have this extension spring I have modeled. When I go to expression and change the the length of the spring the darn Bridge curves jump to the other side of the helix. Is there a way to keep this from happening ARRGGHH? We are using NX 7.5. This spring has a little bit of a taper to the coils so it is not just and easy extension spring. If you have any other robust way of modeling I am all ears. Can not wait until we get NX8.5 for the helix funtion update. What is the best way of tying the round ends into the Coil?
RE: Bridge Curves Jumping on Helix Curve NX7.5
Note that since your 'Law Curve' appeared to be a simple 'Helix' I replaced it with a Helix feature. I also removed the Edge Blend since it was no longer needed (these features are still there but have been suppressed so that you can see exactly what I did).
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thanks again
Shane
