Virtual pivot hinge
Virtual pivot hinge
I am looking for a hinge mounted on the back of a panel that will allow pivot front edge of panel. See attached image.
Hinge must be mounted on back not within panel like many consealed hinge.
Should be able to take horizontal moment load of about 10Nm . Opening 0-30 deg
I am guessing somee variation on type below: But I would like pivot point 70-100 mm in fornt of hinge mounting
http://machinedesign.com/article/where-did-the-hin...
http://baileymarine.co.uk/images/custom/concealed_...
Any pointers welcome.
Many thanks
Many thanks
RE: Virtual pivot hinge
I need something bigger. I saw hinge for door of integrated domestic fridge which could pivot about 15mm offset from mounting comprising 5 links. I would need something scale up for 80 mm offset.
I suppose I could design my own but that sounds like work,
Maybe you should post a drawing of the hinge location and show a few positions of the panel.
I think we may be able to help you through it.
