Change color by name?
hi,
I would to make a macro to change CATPart(s) color in CATProduct according to their names.
I always have the same names and I'd like standardizing colors for every part (ex: "screw" in blue, "nut" in yellow, "washer" in green
Have you an idea?
Thank's!
time to loose: http://www.flickr.com/people/12898221@N08/
RE: Change color by name?
Bellow is a simple example, modify the code according to your needs
CODE --> CATScript
Language="VBSCRIPT"
Sub CATMain()
Dim productDocument1 As Document
Set productDocument1 = CATIA.ActiveDocument
Dim selection1 As Selection
Set selection1 = productDocument1.Selection
selection1.Search "CATProductSearch.Part.PartNumber=screw*,all"
Set visPropertySet1 = selection1.VisProperties
visPropertySet1.SetRealColor 0,128,255,1
Set visProperties1 = CATIA.ActiveDocument.Selection.VisProperties
visProperties1.SetRealOpacity 255,1
selection1.Clear
End Sub
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
