Rectangular pressure vessel design
I want to design rectangular pressure vessel shell. I t is made up of 2 L shape plates.plate dimensions are L=4000mm,W=779,H=1765.
plz help me
RE: Rectangular pressure vessel design
No.
We do not know enough to recommend ANYTHING to you: Not safely nor economically nor prudently nor within industry and government codes.
I can recommend one thing, that is this: This subject has been and continues to be discussed regularly on this site. Do a search.
Mike
Mother Nature only makes round and rounded things. This is a hint that square-cornered pressure vessels are a Bad Idea. If square worked well, you could find a square tree.
On page 213 of the pressure vessel handbook(Eugene Megyesy) there is a reference on the design of Rectangular tanks under hydrostatic pressure. Check it out.
strauss
Obround design covered in ASME BPVC section VIII div 1.
