Concrete Piling Productivity
Hey Guys,
I'm trying to find some data regarding productivity for concrete piling. In the early stages of deciding whether or not it would be worth it to add it as a service in the company I'm with, currently. If anyone has any data or where to get data for drilling (varying depths and diameters) productivity/day ie: number of holes drilled or for the operation together (drill, place cage, casing, pour) it'd be much appreciated. Obviously, the data would be dependent on a lot of factors but need some place to start.
Thanks for the help!
RE: Concrete Piling Productivity
Hey Kendall,
I am not an expert on piles and most of my experience is with driven or helical piles, not concrete piles. Can you provide more information about what you're doing exactly, its not quite clear if you are in the engineering world but sounds more like the installation end of things?
AO
