Dimension Property Manager
Suspect I "no" the answer, but...
When calling up the Dimension Property Manager to add text such as spacing and so forth to a dimension is there any way to increase the font size in the Dimension Text box? I find it very difficult to read, about as difficult as the text entry box for this website, difference being there is no Preview in Sworks.
Thanks in advance,
Mike
Thanks in advance,
Mike
RE: Dimension Property Manager
Change the screen res? Not sufficient privileges. Get a bigger monitor? Definitely not sufficient priviledges. Besides, where would I put it?
Seriously, I have discovered the pop-up dimension data entry box thing (I don't know the formal name, as with so many things in SW). It seems it will most likely have to serve, and should, once I get used to calling it up.
Thanks to all
Mike
Sylvia
