347 H Valve Material ?
What is the difference 347H - 347 Valve body material?
RE: 347 H Valve Material ?
347H has higher limits on Carbon (and higher tensile strenght, I believe).
rp
Actually H has a min on the C, so that it has to be high carbon.
The alloy is slightly stronger, but has significantly higher creep strength.
Plymouth Tube
The 347H has higher creep strength.
