Low Pressure Air Line - Stainless Steel
I am trying to compose a letter to an engineer requesting that they consider the use of "as-welded" stainless steel 316L pipe and fittings for low pressure air pipe lines utilized in a wastewater treatment plant, in lieu of seamless. The temperature is 280 deg F or less with a test pressure of 50 PSI. The lines are 12" NPS or less stainless steel. Any suggestions or points to make?
RE: Low Pressure Air Line - Stainless Steel
http://www.exair.com/en-US/Primary%20Navigation/Kn...
“The beautiful thing about learning is that no one can take it away from you.”
---B.B. King
http://waterhammer.hopout.com.au/
---B.B. King
