Converting Sketch Point to Datum points
Is there a way to convert sketch points to datum points to be used in piping?
Michael McMillan
http://www.linkedin.com/pub/michael-mcmillan/53/37...
http://cadtechie.blogspot.com/
RE: Converting Sketch Point to Datum points
This can be Toggled back and forth just like Reference and Driving Dimensions can as long as you are in Wildfire 5 Point 0 or greater (Creo #.#) etc.
For Dimensions with Equal Relation E1 E1, E2 E2 set you can convert the dimension E# symbol you want to be a driving dim to a strong dimension and convert the previous driving dim to be Reference in much the same way.
Geometry <--> Construction
Driving <--> Reference
"It's not the size of the Forum that matters, It's the Quality of the Posts"
Michael Cole
Boston, MA
CSWP, CSWI, CSWTS
Follow me on !w¡#$%
@ TrajPar - @ mcSldWrx2008
= ProE = SolidWorks
