Design circuit function
Please can any Body explain the function of this circuit, or how it works ?
HEADS OR TAILS
When the push-button is pressed, the circuit will oscillate at a high rate and both LEDs will illuminate. When the push button is released, one of the LEDs will remain illuminated. The 50k is designed to equalise the slightly different values on each half of the circuit and prevent a "bias."
The designed ciruit is on the link below:
http://talkingelectronics.com/projects/200TrCcts/2...
so why one of the leds are on and other is off when the push bottun is relesed ?
I appreciate your quickly replying .
HEADS OR TAILS
RE: Design circuit function
Sorry this is the specified link for the design :
http://talkingelectronics.com/projects/200TrCcts/i...
http://en.wikipedia.org/wiki/Multivibrator
Benta.
Bill
"Why not the best?"
Jimmy Carter
Thank you All , oh it seems that it has many applications
Maybe REALLY early 60s, but my 62 Impala sported a TRANSISTOR radio...
TTFN
Dad's 60 Impala had the transistor radio. My 57 Buick and every other older car I knew had the a tube type radio and the mechanical multivibrator. Senior citizen question. How many remember waiting for the filaments to warm up in a tube type radio or TV?
Bill
"Why not the best?"
Jimmy Carter
