heat exchanger
heat exchanger
hello, im bill
i want to calculate a heat exchanger for pool.
i have central heating with diesel boiler and i want to connect a heat exchanger for pool heating.
the temperature of the water in the pool i want to be 25 c.
can someone help me;
there is any program for this job or any type for calculate?
thanks
thanks
RE: heat exchanger
Google "pool heating systems" and you should get plenty of info.
RE: heat exchanger
i want to know how to calculate the heat exchanger for pool for this installation or heat exchanger (water/water)
RE: heat exchanger
Good luck,
Latexman
RE: heat exchanger
Once you have a heat loss, you'll have to look at the heat source and its temperature to come up with a circulation rate that will depend how how much dT you can afford to those. Those temperatures along with your pool water will set the dT for the heat exchanger and therefore the size.
That will at least get you started in the right direction. You might also want to talk to some pool companies to see if they supply these type of systems, if so they might have some information for you.
