set the startup width of a block styler dialog
recently I've worked on creating a Java plugin for NX 7.5, using a NX dialog as the ui (block ui styler dialog - saved as a .dlx file). I couldn't figure out how to change/customize the width of the dialog at startup - it always started up with a fixed width.
Does it have something to do with the DialogMemory.dlx mentioned in these posts: http://www.eng-tips.com/viewthread.cfm?qid=305413 and http://www.eng-tips.com/viewthread.cfm?qid=240733 ? Any supplementary tips/suggestions would be appreciated.
Thank you.
Thank you.
