Hydro turbine thrust bearing
80MW kaplan hydro turbine commisioned in 1969, we are experiencing serious thrust bearing overheating for the last three years. The bearing is a self pumping external heat exchangers, we introduced circulating pump to ease the problem but it persists - need your help.
RE: Hydro turbine thrust bearing
What a piece of crap; only 4 decades of service before it starts asking for help!
Mike Halloran
Pembroke Pines, FL, USA
when was last overhaul and inspection?
what changed 3 years ago?
Possibly an overhaul, change in thrust position, a possible maintenance event that went unrecorded that could have damaged the bearing, etc??
