simple question
simple question
simple question
Hello fellas,
I have got one simple question - is there in MC possibility to define a constant in such a manner (eg.):
p := r := 10
instead of writing this in two lines:
p := 10
r := 10
or
p := 10
r := p
I assume that p and r will always have the same value, but for readability of the further code I want to have a different names of these constants. So, must I write 2 lines?
RE: simple question
I'm going to step out on a limb here and guess that you are trying to do something a lot more difficult than your example, because if it was just p and r, you've spent a life time of key-stroke savings in writing your post.
You can of course put them on the same line, but that doesn't answer the broader question. You could do it with a vector:
i:0,1;1
pr[i:10
That would let you use pr[0 and pr[1 Still takes two assignments, but if you wanted to assign a dozen variables with the same value it would work.
David Simpson, PE
MuleShoe Engineering
"Belief" is the acceptance of an hypotheses in the absence of data.
"Prejudice" is having an opinion not supported by the preponderance of the data.
"Knowledge" is only found through the accumulation and analysis of data.
The plural of anecdote is not "data"
RE: simple question
My program is quite complex, but this doesn't matter. I was just curious if there is such a way of writing the input data (like p := r := 10). Such a "feature" would be very helpful, shortening the code and make it more clear. I don't want to deal with vectors in such a case. Anyway, thanks for reply.
