Alloy Depletion
Alloy Depletion
thread330-228257: Alloy Depletion
I stumbled upon this thread today and was wondering if anyone else has had success with the creation of Alloy Depletion.
We are going to use this as training material and would like to create a fairly uniform layer of Alloy Depletion on 718 material.
We have both vacuum and conventional furnaces available but would prefer to use vacuum. The thought there would be that vacuum may yield a more uniform layer.
We will probably be using 3/8-1/2" diameter bar stock that has been ground as a starting point.
RE: Alloy Depletion
RE: Alloy Depletion
I know I can create it in a conventional furnace, i have been successful at that already. This time I am trying to create a very precise amount that is uniform in depth and I was wondering if anyone has had success doing this and if so if a vacuum furnace might be better choice for the experiment.
