How to connect Dyn1 and Dyn11 power transformers in parallel operation?
Hi everyone,
Would like to ask your ideas on how to do parallel operation for two transformers with different vector configuration, Dyn1 and Dyn11.
If possible, what are the connections to be done?
GRAEE
RE: How to connect Dyn1 and Dyn11 power transformers in parallel operation?
I would appreciate if you can recommend some references related to this parallel operation.
Thanks.
If I read the question as posed then it is not possible to parallel without modification as suggested by Sibeen
