Flat pattern. Bend lines are not dotted dashed.
Hello everybody,
I have sometimes the problem that the bend lines in a flat pattern are continuous instead of dotted dashed.
If i look at the View Style, tab Flat pattern, of the flat pattern it says that the Bend-Up Center and the Bend-Down Center are Dotted Dashed. But in the flat pattern view i see the bendline as continuous.
Do i overlook something?
Thanks already.
Tjeerd
Using NX 8.0 on Windows 7 (64)
RE: Flat pattern. Bend lines are not dotted dashed.
The same setting is present under preferences-sheet metal.
Remember to stay in the sheet metal envirnment.
Thank you...
Using NX 8 and TC9.1
Thanks. That solved my problem.
NX keeps surpricing me. There are so many places where you can set adjustments..... Sometimes it drive's me crazycyclops
