Properties of Heat dissipation under vacuum
Curious if anyone can point me to some info on how heat dissipates under vacuum. Think in terms of a chamber full of warm silicon wafers and how that heat would dissipate. Would it be signifigantly slower than at atmosphere? Thanks
RE: Properties of Heat dissipation under vacuum
Planck's blackbody function describes the problem.
Time is dependent on how the wafers are supported. If they are on a planetary, there is some amount of conduction, and without air, there is no convection.
TTFN
TTFN
