High leg incoming service - 3 phase 2legs 120 0ne leg 210V
On a incoming service 3phase 240V phase to Phase. 2 legs
are 120 against neutral one leg is 208 V.
The incoming service is 600 A. The high leg has only a 15
HP compressor connected. The air compressor cuts in and out. I am trying to correct the PF which is .85 and .90
on the legs used for lighting etc. and .14 at no load on the
high leg when the compressor runs the PF is .75 [high leg]
the monthly power consumption is 8000 Kwh. Kw demand is 24.
What can be done to improve the power factor on this system.
The voltage THD is 7.5%. The amperage THD is 17%.
Thank you
Have a nice Day
Fritz <LiteIt@ptd.net>
Thank you
Have a nice Day
RE: High leg incoming service - 3 phase 2legs 120 0ne leg 210V
please provide E Mail address or Phone#
Thank You and have a nice day.
<LiteIt@ptd.net>
Fritz
01-919-856-2390 for ABB, Mr. Eric John, email: eric.john@ustra.mail.abb.com
Why can the high leg be used as straight 208 V single Phase,
or with help of a transformer be used as 120/240 V ?
I have a 200A 3 phase service and the high leg is used for
a 15 HP air compressor and nothig else.
Would it not be better for the system if the high leg was
loaded ? It would increase the available power.
Am I wrong in assuming this?
Thank and have a nice day.
LiteIt Fritz
<LiteIt@ptd.net>
