Disengage and rotate drive shaft
I have a motor driving a 2:1 ratio gearbox which drives two drive shafts. I want to be able to stop the machine and manually disengage one of the shafts, rotate it through approx 10 degrees and then re-engage. Could anyone point me in the direction of a device or coupling that is capable of doing this? Many thanks in advance for your help.
RE: Disengage and rotate drive shaft
http://www.candycontrols.com/PhasingHub/PhasingHub...
