Y14.5-1994
Y14.5-1994
Y14.5-1994
Where is the best place to go to get the actual manual even a used one.
RE: Y14.5-1994
Use the ISBN for that 1994 standard to make it easier to search:
9780791822234
It is available from the publisher (go to www.asme.org) or usually a used copy is available for a little less through Amazon.
FYI, the current edition of the standard is 2009, but it sounds like you really want the 1994 edition.
John-Paul Belanger
Geometric Learning Systems
http://www.gdtseminars.com
RE: Y14.5-1994
I have the 2009 update but everybody else here uses -1994
