Comparison of High Pressure Valve
In the market, there are a few company which fabricate valve, fitting and tubing. Can anyone tell me more about the pro and corn for each individual company( Autoclave Engineer, Butech and HIP). Please advise me, help!
RE: Comparison of High Pressure Valve
There would certainly be pros and cons for a specific product from two specific manufacturors, for a specific application, with all flow and product specifications given.
Your question is unfortunately formed as a general technical/commercial market research survey, and as such not quite the question suited or likely to get you an answer from this forum.
Check out eng-tips policy, and I suggest you rephrase, specify and start a new thread.
