R value for a reinforced concrete frame structure
This is a 1920s reinforced concrete moment structure in Seismic Design Category D.
In the other direction, it has masonry infill between the columns and beams, however in the direction I am working on, there is nothing resisting seismic shear except for the concrete frame and the steel moment frame(s) we are installing (either intermediate or ordinary). The frames will be able to withstand at least 25% of the ASCE7-05 seismic loads.
My question to you is: what would you use for the all-important R value?
RE: R value for a reinforced concrete frame structure
FEMA 356 Prestandard and Commentary for the Seismic Rehabilitation of Buildings http://www.fema.gov/library/viewRecord.do?id=1427
FEMA Techniques for the Seismic Rehabilitation of Existing Buildings http://www.fema.gov/library/viewRecord.do?id=2393
ASCE 31-03 Seismic Evaluation of Existing Buildings http://www.asce.org/Books-and-Journals/Books---Per...
ASCE 41-06 Seismic Rehabilitation of Existing Buildings http://www.asce.org/Books-and-Journals/Books---Per...
