connection
connection
I like to know which is the best way to connect horizontal diagonal bracing to beam and column. A beam is connected to column flange with clip angle on each side of beam welded and bolted to column flange. Beam W10x33 Column W14X90 Diagonal bracing double angle 4x4x.5
RE: connection
BA
RE: connection
RE: connection
RE: connection
RE: connection
See AISC 13th Ed page 13-6 for an illustration. (or in the LRFD 3rd Ed. on page 13-7] If you are designing steel, you need the AISC Steel Construction Manual. Generally, I don't separate connections for shear and lateral, since they have to act in concert.
