Frost Depth for Grade Sloping Away from Building
Is there a certain distance out from a building that grade elevation must be maintained to make sure a foundation is at frost depth. I ask this because I had designed a perimeter stem wall and footing for a building with the bottom of footing placed at frost depth, but I have found out that there is going to be pretty decent grade slope away from the building. I could not find anything in the IBC that covered this.
RE: Frost Depth for Grade Sloping Away from Building
Mike Lambert
