wood core sample tools?
Doing some searching here and reading over the years I found a lot of you use a core sampler called an "increment borer". I am interested in finally getting something to take wood samples with. I have located suppliers for these but I am looking for some feedback. These look like they are designed for tree samples so they have this big handle which needs some clearance. Since what I am looking for is to use it in the confines of a crawlspace or attic or between 16" o/c joists and there is a floor deck above and I need to sample small lumber at times I am wondering some things:
1) if this is in fact the best tool or if there is something else out there? Small like a wine cork screw size?
2) Any experiences or pros and cons to this type of tool? Troubles? ease of use?
3) Bit size recommendations?
______________
MAP
RE: wood core sample tools?
______________
MAP
Dik
Not to be personal, but I am interested in the size of it.
______________
MAP
The borer 'collapsed' is 19" long by 3/4" dia. Assembled it is 18" long (auger part) x 18.5" (handle). You may be able to sample parts of conventional wood frame construction, but not all parts.
Dik
