Curve through X & Y value in excel
Hi Guys,
I have a x and y value in excel sheet and I would like to make a curve from the date. Please suggest any advise.
Thank you
regards
Rodney
Thank you
regards
Rodney
RE: Curve through X & Y value in excel
What NX version you are on?
Best Regards
Kapil Sharma
In that case first of all you can save the excel sheet in a tab delimited format (for example i saved it in .txt format).
Now go to file/Import/Points from file and import these points (it will create a seperate Group consisting of all these points) and the use INSERT/CURVE/FIT CURVE/FIT SPLINE and select the Group to craete a spline.
Bestr Regards
Kapil
Thanks and Best Regards
Kapil
regards
Rodney
