Triangular splines 90 degrees Standard - DIN, ISO or ASA
I need triangular splines 90 degrees Standard - DIN, ISO or ASA. Please help me.
RE: Triangular splines 90 degrees Standard - DIN, ISO or ASA
I think you mean 45deg pressure angle, 90deg included.
45deg PA spline standards are available from most of the standards institutes.
Just do a Google search and select the ones appropriate to your country.
Ron Volmershausen
Brunkerville Engineering
Newcastle Australia
http://www.aussieweb.com.au/email.aspx?id=1194181
