Standard Weld Details and Galvanizing
AISC is quite specific about not welding across the beam web thickness when attaching a shear end-plate. See AISC 13th ed., page 10-49. Other types of shear connections have similar requirements that prohibit complete welding. It's not uncommon at all to have a beam with a shear end-plate that gets galvanized. "Common" knowledge among most fabricators is that things that get galvanized get completely seal welded so the acid or whatever doesn't get in cracks. So AISC is telling us one thing and the fabricator another. Who is right? Surely the folks that wrote the AISC code realized that a goodly portion of fabricated steel is going to get dunked in a vat of molten zinc, so I'm thinking they wrote exactly what they meant and this seal welding idea isn't really valid. Of course, I could be completely wrong, in which case what's a feller to do?
Don't get to hung up on shear end-plates, that's just what I happened to be working on so I used that as an example. Shoot, look at double angles welded to the end of beams as a shear connection. Again, AISC says welding across the entire top of the angle must be avoided as it would inhibit the flexibility. It doesn't say unless beam assembly is to be galvanized.
By the by, I know somebody is going to say something like you seal weld and a seal weld is not a structural weld. I'm not buying that. First, just exactly what size is a seal weld? Is this seal weld so flexible it will allow the beam to rotate but not crack the weld?
Anyway I sure would like to know the straight skinny on this. Thanks.
RE: Standard Weld Details and Galvanizing
If so, what is the concern there?
I must admit, it does make sense that having "cracks" that the pickling liquid could get into and possibly trapped there by the galvanizing would be a bad thing. The stories I've heard is it leads to corrosion from the inside. Hey, I'm just reporting the news.
http://www.gaa.com.au/uploads/Wall%20Chart.pdf
Best regards - Al
