Steel Pipe Pile
Steel Pipe Pile
Hi guys,
Please help me
how to design or check steel pipe pile?
please teach me step by step
what data need to be used?
There are a lot of formula to calculate the bearing capacity such as Meyerhof, Luciano Decourt, Van Der Ween, etc.
Are those formulas applied to both concrete pile and steel pile?
If I use different steel strength of pipe pile, where will it be affected?
when should we consider the friction capacity and or end bearing capacity?
Please your kindly advice and explanation.
Thanks a lot.
Best Regards
Yusak
Please help me
Thanks a lot.
Best Regards
Yusak
RE: Steel Pipe Pile
Mike McCann
MMC Engineering
RE: Steel Pipe Pile
www.PeirceEngineering.com
