Possible to have text parallel to grid in 2D view
Creating a new 2D drawing.
When puting a thickness dimension on a section in a view the resulting dimension text is on an angle.
Is it possible to change it so the text will always be horizontal.
when using more sophisticated CAD programs the default positioning is always horizontal so the text is easy to read, not so with with NX.
This is version 7.5 if it matters.
RE: Possible to have text parallel to grid in 2D view
To make this the default for future drawings, you will have to change your template files and/or customer defaults.
www.nxjournaling.com
